As the subject says, Usermin works fine for sending and receiving email. But when I used a mail client like Outlook, I cannot send email. It asks for the username and password.
In my mail.log I have:
Jul 11 13:46:07 server postfix/smtpd[13917]: connect from 216-19-178-200.stc.novuscom.net[216.19.178.200]
Jul 11 13:46:07 server postfix/smtpd[13917]: warning: 216-19-178-200.stc.novuscom.net[216.19.178.200]: SASL LOGIN authentication failed: authentication failure
Jul 11 13:46:07 server postfix/smtpd[13917]: lost connection after AUTH from 216-19-178-200.stc.novuscom.net[216.19.178.200]
Jul 11 13:46:07 server postfix/smtpd[13917]: disconnect from 216-19-178-200.stc.novuscom.net[216.19.178.200]
/etc/default/saslauthd:
Settings for saslauthd daemon
Please read /usr/share/doc/sasl2-bin/README.Debian for details.
Should saslauthd run automatically on startup? (default: no)
START=yes
Description of this saslauthd instance. Recommended.
(suggestion: SASL Authentication Daemon)
DESC=“SASL Authentication Daemon”
Short name of this saslauthd instance. Strongly recommended.
(suggestion: saslauthd)
NAME=“saslauthd”
Which authentication mechanisms should saslauthd use? (default: pam)
Available options in this Debian package:
getpwent – use the getpwent() library function
kerberos5 – use Kerberos 5
pam – use PAM
rimap – use a remote IMAP server
shadow – use the local shadow password file
sasldb – use the local sasldb database file
ldap – use LDAP (configuration is in /etc/saslauthd.conf)
Only one option may be used at a time. See the saslauthd man page
for more information.
Example: MECHANISMS=“pam”
MECHANISMS=“pam”
Additional options for this mechanism. (default: none)
See the saslauthd man page for information about mech-specific options.
MECH_OPTIONS=""
How many saslauthd processes should we run? (default: 5)
A value of 0 will fork a new process for each connection.
THREADS=5
Other options (default: -c -m /var/run/saslauthd)
Note: You MUST specify the -m option or saslauthd won’t run!
WARNING: DO NOT SPECIFY THE -d OPTION.
The -d option will cause saslauthd to run in the foreground instead of as
a daemon. This will PREVENT YOUR SYSTEM FROM BOOTING PROPERLY. If you wish
to run saslauthd in debug mode, please run it by hand to be safe.
See /usr/share/doc/sasl2-bin/README.Debian for Debian-specific information.
See the saslauthd man page and the output of ‘saslauthd -h’ for general
information about these options.
Example for postfix users: “-c -m /var/spool/postfix/var/run/saslauthd”
OPTIONS="-c -m /var/spool/postfix/var/run/saslauthd"
/etc/postfix/main.cf
See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = /usr/share/doc/postfix
TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
#myorigin = $mydomain
mydestination = $mydomain, localhost.$mydomain, localhost
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
html_directory = /usr/share/doc/postfix/html
home_mailbox = Maildir/
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $mydomain
smtpd_recipient_restrictions = permit_mynetworks,permit_sasl_authenticated,reject_unauth_destination
mail_spool_directory = /home/mail
Please advise
