There were a bunch of theme errors - and I remembered that I had to change theme’s previously to get it installed! Changed theme, installed and then back again!
Here are the errors for ref - lots and lots of these:
Use of uninitialized value $settings{"settings_sysinfo_real_time_statu"...} in string eq at /usr/libexec/webmin/authentic-theme/stats.cgi line 25.
Is this an issue on their part or something you might need to rectify?
I don’ t want to take over this subject, but found this while searching why my hamtrap does not work and found the same errormessages as above.
Does someone know what the problem might be?
