Unable to install RoundCube using script
Hi all
I tried to install RoundCube using installation script, but this is the error message:
“This script cannot be installed, as this virtual server does not meet its requirements : A MySQL database is needed”.
My Virtual Server name is “lecollinedelmare.it”.
I tried to edit the Virtual Server and enabling MySQL database, but I got another error message because a database called “lecollinedelmare” already exist (I created it outside VirtualMin).
What you could do is turn off creation of the initial MySQL database.
To do that, go into System Settings -> Server Templates -> Default Settings -> MySQL Database -> “Create database as well as login?”.
Once that is done, you should be able to enable the MySQL feature … and then import the database at Edit Databases -> Import.
Very good.
Thank you Eric :slight_smile:
