Well, this may be due to the lack of sleep that you described, but I’m having a bit of trouble following what problem you’re having there
It sounds like you mentioned that you’re having a problem FTP’ing? If so, what are the errors that you’re seeing? Can you paste in the full error messages?
You pasted in an error at the end there that appears to be a Virtualmin error – when does that occur exactly? Does that occur when trying to create a user?
Your system has 2 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Your Postfix version does not support per-domain outgoing IP addresses.
Apache is installed.
The following PHP versions are available : 5.3.3 (/usr/bin/php-cgi)
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and running.
Plugin DAV Login is installed OK.
The AWstats command /usr/share/awstats/wwwroot/cgi-bin/awstats.pl was not found on your system.
Hmm, well, you didn’t mention what errors you were seeing when trying to FTP, but I have a suspicion what they might be based on your “ls” output.
It looks like the “/home/bestseodeal/etc/” directory is owned by the user/group “bestseodeal”.
However, the /home/bestseodeal directory is owned by “iamjim”.
Those dirs are typically all owned by the same user though.
Knowing that, I suspect that some permissions got changed somewhere along the way that are causing some problems.
What you may want to do is go into Limits and Validation -> Validate Virtual Servers -> Fix Permissions, and you may want to have it fix the permissions on that particular domain.
After doing that, does FTP begin working properly for you?
Howdy Eric, and of course (haven’t said it yet) but thanks for trying to help. And yes, after the first output and before I replied (or opened my mouth) I had tried it as user > iamjim < yesterday
1) For simpletons sake, to verify (I hope) that nothing I did
a) create new and "simply" try again
[root@lassd virtualmin]# pico businessdatabaselist.com_error_log
[Wed Dec 17 05:57:47 2014] [error] [client 66.153.xxx.xx] Directory index forbidden by Options directive: /home/bizdata/public_html/
[Wed Dec 17 05:57:49 2014] [error] [client 66.153.xxx.xx] File does not exist: /home/bizdata/public_html/favicon.ico
Above, was trying to FTP in, to a newly created account
Tried domain based first, then IP based
[root@lassd virtualmin]# htop
Did your Permissions trick fix, on the one domain = output
[root@lassd virtualmin]# ls -la /home/bestseodeal/etc/
total 16
drwxr-xr-x 3 bestseodeal bestseodeal 4096 Oct 6 07:29 .
drwxr-x--- 12 bestseodeal bestseodeal 4096 Dec 17 05:51 ..
-rw-rw-r-x 1 bestseodeal bestseodeal 111 Oct 6 07:29 dav.digest.passwd
lrwxrwxrwx 1 bestseodeal bestseodeal 12 Oct 6 07:29 php.ini -> php5/php.ini
drwxr-xr-x 2 bestseodeal bestseodeal 4096 Oct 6 07:29 php5
[root@lassd virtualmin]# ls -la /home/bizdata/etc/
total 16
drwxr-xr-x 3 bizdata bizdata 4096 Dec 17 05:56 .
drwxr-x--- 11 bizdata bizdata 4096 Dec 17 05:56 ..
-rw-rw-r-x 1 bizdata bizdata 107 Dec 17 05:56 dav.digest.passwd
lrwxrwxrwx 1 bizdata bizdata 12 Dec 17 05:56 php.ini -> php5/php.ini
drwxr-xr-x 2 bizdata bizdata 4096 Dec 17 05:56 php5
OK, tried the bestseodeal FTP in again. 530 password error.
Now, day 3 of 10% of my days on this, [and armpits working up a small sweat as well] and this was after as i mentioned 2 months ago install…and tossing this aside for the same reasons after doing the install
[just venting], and kicking myself in the butt for not taking Nick’s cpanel job offer up back in 2004 after they outsourced at Microsoft.
Over a year ago, I tossed this up and had no problems at all brother?
Thanks again for the help, BUT?
Today should be a less hectic day, so I’ll be able to respond faster also sir.
The errors you’re seeing in “businessdatabaselist.com_error_log” are normal website related errors, those aren’t FTP errors. You’d get those errors if you were trying to access a website that didn’t have a website uploaded yet.
Your permissions appear to be correct now.
Now, regarding logging in – what distro/version is it that you’re using there? If you’re using CentOS, what is the output of this command:
rpm -qa | grep proftp
Also, I’m curious if you’re able to access your accounts using SSH or SCP, rather than FTP (at least as a test, though note that if possible, SSH/SFTP is a much more secure protocol anyhow, you can use a tool such as WinSCP to access that).
And I know you’re just venting, but we normally don’t see these sorts of issues… I don’t think you’re running into a Virtualmin vs cPanel sort of problem here
Ah, it looks like your FTP package came from a third party, which can cause the problem you’re experiencing.
Take a peek at the article titled “Why does PHP / ProFTPd no longer work after performing updates? (I’m using CentOS, and enabled third party repositories)” here:
Haha - All in jest brother, uploading now finally (2 months later back at the ranch) and for sure know how one forgets things… I’ve forgotten all the eprom programming I’ve done in the late 80’s
