I’ve entered the dmarc settings incorrectly and now it’s showing there is a Fatal error. I would like to correct the mistake, however I am now unable to edit the DNS records. I hope someone can help.
If you use the console icon you should be able to manually edit the file.
Can you connect to dns server over ssh to ip address? If yes, then have remotely “repairable” error. And this not fatal. You can edit zone records manualy and reload or restart dns. Or did I misunderstand what was written?
is your DNS local (on the same server as Virtualmin), or at your ISP?
Screenshot the issue/error might help.
Thanks so much for all your help! I think maybe my description wasn’t very clear. I deleted the file through the file manager and the issue resolved. Thanks again!
