Just installed Virtualmin on Ubuntu 18.04.
The ProFTPD module responds:
The program /usr/sbin/proftpd does not appear to be the ProFTPD server. Maybe it is not installed, or your module configuration is incorrect. Output from the command /usr/sbin/proftpd -v was :
Command netstat -aln | grep :21
output:
tcp6 0 0 :::21 :::* LISTEN
Command which proftpd
output:
/usr/sbin/proftpd
Command /usr/sbin/proftpd -v
output from terminal:
ProFTPD Version 1.3.5e
What’s wrong here?
Thank you very much.
