I was setting up a new server today, moving sites off the old server to a new server to split the load, at some point the old server stopped serving pages, I stopped to fix it, but found I could not get the Connectivity Check to pass, and I get the mod_fcgid Premature end of script headers error, I see that a lot in the log, but it never took down the site before.
CentOS 5.9
PHP 5.2.17
Everything up to date.
Using bleeding edge repo, site has been running fine for years, didn’t mess we settings, just deleted some web sites.
I have been researching this all night and not getting any closer to finding a fix, I do have Virtualmin pro running on both servers right now, same license, until I get all sites balanced, so I know which license I need to buy, don’t see why that would cause problems, but I am running on empty finding a solution to bring the server back up, I took the new server down, thinking it was the license, but that did not solve the issue, new site works fine.
Php runs fine from command line, HTML will server fine, but not php,
The log does register the error each time, so DNS seems to be working, so why Connectivity Check fails now is beyond me, it doesn’t seem that deleting web sites should do this.
Validate Virtual Servers passes, and so does Checking Configuration.
Changing to cgi gives same failure, and I have time out set to unlimited.
Virtualmin runs fine using the same url as one of the sites that will not pull up, which really makes me wonder why that is, but I looked at the config, and it seems to set aside some things for port 10000.
Any help would be great.
