Hi, I am trying to install twiki thru "install scripts" under "virtual server" . I got this error when i click on "show install option "[color=#FF0000]"This script cannot be installed, as it requires the following commands : rcs"[/color] . Is there anything should be done before the script installation?
Nay
p.s I am using EC2 pro AMI "ami-6d4ca904"<br><br>Post edited by: nay, at: 2008/12/18 11:12
[color=#A7A7A7]“Total download size: 332 k
Is this ok [y/N]: Traceback (most recent call last):
File “/usr/bin/yum”, line 29, in ?
yummain.main(sys.argv[1:])
File “/usr/share/yum-cli/yummain.py”, line 172, in main
base.doTransaction()
File “/usr/share/yum-cli/cli.py”, line 413, in doTransaction
if not self.userconfirm():
File “/usr/share/yum-cli/output.py”, line 115, in userconfirm
choice = raw_input('Is this ok [y/N]: ')
EOFError: EOF when reading a line”[/color]
Sorry below is the complete one. I am using "shell command" under webmin
"> yum install rcs
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
Reading repository metadata in from local files
Parsing package install arguments
Resolving Dependencies
–> Populating transaction set with selected packages. Please wait.
—> Package rcs.i386 0:5.7-30.1 set to be updated
–> Running transaction check
Dependencies Resolved
Package Arch Version Repository Size
Could you try logging in over SSH rather than using Webmin’s shell? Yum probably uses the Ncurses library to display it’s output, and that may be why it’s not working right through Webmin.
Alternatively, you could go into Webmin -> System -> Software Packages and install rcs from within there.
Total download size: 29 M
Thanks Eric
It is working when I try from Webmin -> System -> Software Packages … Must be the user level. I’ve installed rcs and twiki. btw, in webmin>commandshell how do you login as root?
The Software Packages module can also install the package for you…if you must use Webmin.
But, as ronald mentioned, you can’t run an interactive application in the Command Shell. (So, you could use “yum -y install rcs”. But there is a module specifically for installing packages, so if you’re going to use Webmin, use the module for the purpose.)
