I’ve been scratching my head about this for a long time, trying to get it to work.
I am getting 403 permission denied when trying to access the website.
Here are my config files:
Directives for Virtual Host
SuexecUserGroup "#533" "#526"
ServerName domain.com
ServerAlias www.domain.com
ServerAlias webmail.domain.com
ServerAlias admin.domain.com
DocumentRoot /home/domain/public_html
ErrorLog /var/log/virtualmin/domain.com_error_log
CustomLog /var/log/virtualmin/domain.com_access_log combined
ScriptAlias /cgi-bin/ /home/domain/fcgi-bin/
ScriptAlias /awstats/ /home/domain/cgi-bin/
<Directory /home/domain/public_html>
Options -Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch +ExecCGI
allow from all
AddType application/x-httpd-php .php5
AddHandler fcgid-script .php
AddHandler fcgid-script .php5
FCGIWrapper /home/domain/fcgi-bin/php5.fcgi .php5
</Directory>
<Directory /home/domain/cgi-bin>
allow from all
</Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.domain.com.
RewriteRule ^(.*) https://domain.com.:24984/ [R]
RewriteCond %{HTTP_HOST} =admin.domain.com.
RewriteRule ^(.*) https://domain.com.:14984/ [R]
Alias /dav /home/domain/public_html
<Location /dav>
DAV on
AuthType Basic
AuthName "domain.com."
AuthUserFile /home/domain/etc/dav.digest.passwd
Require valid-user
ForceType text/plain
Satisfy All
RewriteEngine off
</Location>
<Files awstats.pl>
AuthName "domain.com. statistics"
AuthType Basic
AuthUserFile /home/domain/.awstats-htpasswd
require valid-user
</Files>
IPCCommTimeout 61
RemoveHandler .php
RemoveHandler .php5
php_admin_value engine Off
FcgidMaxRequestLen 1073741824
Here is my php.con in /etc/httpd/conf.d/
# PHP is an HTML-embedded scripting language which attempts to make it
# easy for developers to write dynamically generated webpages.
<IfModule prefork.c>
LoadModule php5_module modules/libphp5.so
</IfModule>
<IfModule !prefork.c>
LoadModule php5_module modules/libphp5-zts.so
</IfModule>
# Cause the PHP interpreter to handle files with a .php extension.
<FilesMatch \.php$>
SetHandler application/x-httpd-php
</FilesMatch>
# Allow php to handle Multiviews
AddType text/html .php
# Add index.php to the list of files that will be served as directory
# indexes.
DirectoryIndex index.php
# Uncomment the following lines to allow PHP to pretty-print .phps
# files as PHP source code:
#<FilesMatch \.phps$>
# SetHandler application/x-httpd-php-source
#</FilesMatch>
# Apache specific PHP configuration options
# those can be override in each configured vhost
php_value session.save_handler "files"
php_value session.save_path "/var/lib/php/session"
php_value soap.wsdl_cache_dir "/var/lib/php/wsdlcache"
And here is /home/domain/fcgi-bin/php5.fcgi
PHPRC=$PWD/../etc/php5/
export PHPRC
umask 022
SCRIPT_FILENAME=$PATH_TRANSLATED
export SCRIPT_FILENAME
exec /usr/bin/php-cgi
Directories are all 755 except for public_html which is 644.
I would be really thankful if someone could help me!
