/tmp is mounted as noexec - workaround?
Trying to run the Virtualmin GPL script but due to /tmp being mounted as noexec it won’t run.
RATHER than me finding the commands to unmount / remount the directory… can I just cheat and change the install.sh to point to a different local path and safely delete said “tmp” directory after the script is done?
IE: /home/gpltmp
I found where to change it in the script, do I just have to change 1 single line for it to work?
Ah bugger it, spent time finding out how to remount it easily.
Simply
mount -o remount,exec /tmp
run the script
mount -o remount /tmp
So that it loads the settings from fstab!! :smiley:
