does virtualmin directly support mod_throttle…aka i want to be able to limit my client to a megabit or 2 or whatever i want to be able to limit them to. I i have to go directly into apache that’s ok…just waned to see if virtualmin has a panel to access that…
Hey William,
We’ve never had a request for it, so it’s not covered by Virtualmin in any way. I don’t think the Apache module covers it either…so you’ll probably need to drop right into httpd.conf to set it up. Virtualmin won’t break it once you set it up, though.
consider this a feature request then…
