I’m getting “The connection has timed out” when trying to access https://mysitesip:10000 or https://mydomainname.com:10000.
Is Webmin currently running on your server?
You can verify that by executing this command as root on the command line:
/etc/init,d/webmin restart
After running that, are you able to access port 10000?
After running the command I can’t access port 10000.
I did change the command to /etc/init.d/webmin restart instead of /etc/init,d/webmin restart.
Sorry, that was a typo. After correcting the command as you showed above, did that resolve the problem?
If not, what is the output of this command:
netstat -an | grep :10000
tcp 0 0 0.0.0.0:10000 0.0.0.0:* LISTEN
udp 0 0 0.0.0.0:10000 0.0.0.0:*
Okay, so Webmin is indeed listening for a connection. That means something else is causing the problem
Could your ISP be blocking port 10000? Or a firewall? Also, if you’re running your server behind a NAT router, you’d need to make sure you’re forwarding port 10000 from the router to the server.
Yeah Firewall was blocking it, I added it and now is fixed. Thanks you for the help!
