For some reason, today I checked configurations again and it is working now. Don’t know what I did?
I unchecked Virus Filtering and Spam Filtering as well as you said, but that was after the fact. The installation is working with them checked or unchecked.
I did receive this warning though:
“Virtualmin could not work out the default IPv6 address for virtual servers on your system. You will need to update either the Network interface for virtual addresses or Default virtual server IP address fields on the module configuration page.”
Does checking the “Trust links from unknown referrers” solve this warning?
So far the only thing I’ve installed is VirtualMin and everything that comes with it on a fresh Ubuntu 12.0.4 server.
Everything seems to be working so far now, so I’m not sure of the implications of that warning, which is why I was asking. I’m trying to future proof this installation as much as possible.
If you aren’t planning on using IPv6 at all, you can safely ignore that warning message.
If one day, you wish to use IPv6 – once you setup IPv6 addresses, you can then go into the Network Settings that the warning referenced in order to configure the default IPv6 address to use.
