Hello everybody,
I be impressed about the cloudmin and virtualmin tools since years.
Thank you for that!
I have prepared a new server with cloudmin GPL and create some KVM
instances. E.g. the instance for portal has 25 GB virtual disk operates
with Ubuntu from your image server.
I got the followings error with the creation
expansion failed : parted -s /dev/vgstorage/test-srv-001_cloudmin_xxxxx-yyyyy_net_img mkpart primary 1048576B 26843M failed : device-mapper: deps ioctl failed: No such device or address
If I take a look inside the newly created system, I have only 1 GB space
on the maschine inside the file system / !!! But I can see the full disk space
with 25 GB at the partition.
What happens with the creation of the right size of the file system inside
the virtual maschine? How can I resize the file systems?
Also the gateway will not be set, if I change at the creation process? The
virtual maschine will get the gateway from the host.
Thank you for support in advance.
Cheers, Ralf
------ additional information (output from creation instance) ------
Copying 804.39 MB image file to host system smart-cloud-srv-001.xxxxx-yyyyy.net …
… already on host
Creating virtual system with KVM …
… creation started.
Waiting for creation to complete …
… creation has completed successfully.
Creating swap file of 2 GB …
… creation failed : 65536+0 records in 65536+0 records out 2147483648 bytes (2.1 GB) copied, 29.8528 s, 71.9 MB/s . The Xen instance may not start up
Removing missing disks from fstab file …
… done
Expanding filesystem to 25 GB …
… expansion failed : parted -s /dev/vgstorage/test-srv-xxxxx-yyyyy_net_img mkpart primary 32256B 26843M failed : device-mapper: deps ioctl failed: No such device or address
Mounting new instance’s filesystem …
… mounted on /mnt/kvm-test-srv-002.cloudmin.xxxxx-yyyyy.net
Setting root password …
… done
Adding extra authorized SSH keys …
… done
Updating configuration files with hostname and IP address …
… done
Updating network configuration files …
… done
Modifying /etc/fstab file …
… done
Allowing SSH logins by root …
… already allowed
Setting SSH server port …
… done
Un-mounting instance’s filesystem …
… done
Adding DNS entry test-srv-002.cloudmin.xxxxx-yyyyy.net. for IP address 88.198.140.215 …
… done
Starting up new KVM instance …
… done
Regenerating SSH host keys …
… done
Setting password for existing Webmin install …
… password changed successfully.
Opening firewall ports for Webmin …
… done
Waiting for Webmin to start …
… started successfully
Fetching current status …
… status successfully retrieved (Virtualmin)
Re-fetching current status of host system smart-cloud-srv-001.xxxxx-yyyyy.net …
… status successfully retrieved (Webmin)
Checking Virtualmin configuration …
… all OK.
Enabling system at host boot time …
… done
