My System Time in Webmin no longer shows anything under the tabs “Change Time Zone” or “Time Server Sync”. Used to be just fine. “Set Time” tab still shows up but there is now an error that appears:
hwclock failed :
hwclock --debug shows:
[root@ns1 ~]# hwclock --debug
hwclock from util-linux-2.13-pre7
hwclock: Open of /dev/rtc failed, errno=19: No such device.
No usable clock interface found.
Cannot access the Hardware Clock via any known method.
I don’t use a VPS server. I did just install ntpd on my CentOS 5.3 box and it seems to be working fine in that dovecot is not shutting down due to time moving backwards.
