CPU load averages 0.74 (1 min) 0.69 (5 mins) 0.57 (15 mins)
This has been showing up for the last 85 or so times I logged in.
I can’t remember the day it began, but it is obvious that the information is not being read when the “button is pushed”.
Where can I look to see if the cgi is running correctly, or if I have a permission problem or some such reading /proc ???
Eric
February 17, 2009, 4:08pm
2
Is the collectinfo.pl script running regularly from root’s crontab?
It’s up to you as to how often it should be run, but /etc/webmin/virtual-server/collectinfo.pl should be called regularly – it’s run every 5 minutes by default.
I shall have to look at that.
I assumed the link was an "at the moment" result of the cgi.
Guess I was way off on that one.
Yep. Sure 'nough. It was commented out. I sure don’t remember doing that. Hmmmmm.
Is it possible it was an unfinished upgrade or something that commented it out and not back in?
Oh well, should be fixed now.
Thanks.
