Hello everybody.
I have installed Virtualmin on a bare Centos 6 64 server (see attahed file for full system information with obfuscated IP’s and domains) using the install.sh script, all is working well (so far) however I have a few issue which are nagging me, before posting this I looked around the web to see if there were people with similar problems to no avail, I found plenty of information about setting up the hostname (/etc/hosts, /etc/network/interfaces and system-config-network-tui to name a few tries) but I have a strange one:
The Virtualmin System hostname reports the right hostname but the IP is not correct ( it shows 127.0.0.1 in brakets next to it. in the Sytem Information page).
Also hostname returns the full domain name, I have another Virtualmin and a plesk server which only returns the “hostame” not the “full domain name”. However hostname -f returns “localhost” and when I restart httpd I get a warning:
Starting httpd: httpd: Could not reliably determine the server’s fully qualified domain name, using xxx.xxxxxx.com for ServerName
I would like to ask if there are places I need to look at? or re-install virtualmin? The only bobo I made is to “Skip” (there’s a tickbox) the DNS/BIND virtualmin post install setup as this server is not running named at all.
I am currently not too worried as running external tests seems to return correct information regarding http/smtp/ptr/dns etc. However, as this machine will become a live production system. I don’t wish to spend hours on it only to discover that I should have done something different.
I can always ask the DC to re-image it if required,
Therefore any insights would be greatly appreciated
Gilbert.
