Everything worked fine on Apache with a dynamic IP but now that I’ve switched nothing works.
The static IP doesn’t bring up me default web page like it did before. I have no idea what to look for now and I’m desperate to get my sites back up and running!
Please give some advice. I’ve changed the shared IP address on all of the sites to look at the static IP address, but I’m lost from here.
hello, i have had this very same problem i searched high and low for instances of the Old IP address and found none but things wouldnt go, turns out i had 1 remaining instance in the apache configuration, i dont remember where the one was that i had missed initially but try looking in the Global Modules at "Networking and Addresses" and make sure that things are setup to use the static IP address.
