When I try to use Webmin to switch to a Usermin user, it doesn’t work.
I have both Webmin and Usermin behind Apache reverse proxies. Here is their configuration:
<VirtualHost webmin.xx.xx:80>
ServerName webmin.xx.xx
Include notssl.conf
Redirect temp / https://webmin.xx.xx/
ErrorLog /var/log/apache2/error.log
CustomLog /var/log/apache2/access.log combined
</VirtualHost>
<VirtualHost webmin.xx.xx:443>
Include ssl.conf
SSLProxyEngine on
ProxyPass / http://localhost:10000/
ProxyPassReverse / http://webmin.xx.xx:10000/
ProxyPreserveHost on
Header edit Location http://webmin.xx.xx:20000 https://usermin.xx.xx
</VirtualHost>
<VirtualHost usermin.xx.xx:80>
ServerName usermin.xx.xx
Include notssl.conf
Redirect temp / https://usermin.xx.xx/
</VirtualHost>
<VirtualHost usermin.xx.xx:443>
Include ssl.conf
SSLProxyEngine on
ProxyPass / http://localhost:20000/
ProxyPassReverse / http://usermin.xx.xx:20000/
Header edit Location http://usermin.xx.xx:10000 https://webmin.xx.xx
</VirtualHost>
Webmin & Usermin are both configured to not use SSL, but are blocked behind ufw, so only Apache can communicate with them. Apache uses its own TLS certificates. Webmin and Usermin are both fully functional and there are no issues using them individually (as far as I can tell).
The issue arises when I go to the Usermin Configuration -> Current Login Sessions module and attempt to use “Switch to Usermin user”. When I click the “Switch” button, a new session is created but a new tab opens to the Usermin login page - not to that session.
Am I doing something wrong or is this a bug in Webmin?
