hello again… i already posted a while ago about the traffic spikes i am getting on those high port numbers… we suspected that it was ftp traffic but i stopped the ftp server for a few days now and am still getting the same traffic spikes of multiple gigabytes… i am slightly paranoid because i really dont know what could possibly cause all that traffic (again, it’s not normal email/web traffic)…
i remember you guys talking about checking for suspicious processes but i dont know much about linux so i wouldnt know whether something is legitimate or not… could someone maybe have a look at this list and tell me whether anything looks unusual?
[code:1]29245 www-data 277228 kB java -Dlog4j.configuration=file:conf/log4j-default.properties -Xms3m -Xmx128m -D …
2560 mysql 147832 kB /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file …
11590 www-data 138800 kB /usr/sbin/apache2 -k start
26546 www-data 138800 kB /usr/sbin/apache2 -k start
21878 www-data 138756 kB /usr/sbin/apache2 -k start
21879 www-data 138756 kB /usr/sbin/apache2 -k start
12399 www-data 138756 kB /usr/sbin/apache2 -k start
13617 www-data 138744 kB /usr/sbin/apache2 -k start
6549 www-data 138640 kB /usr/sbin/apache2 -k start
5213 www-data 137200 kB /usr/sbin/apache2 -k start
6683 www-data 136944 kB /usr/sbin/apache2 -k start
6685 www-data 136944 kB /usr/sbin/apache2 -k start
799 root 136152 kB /usr/sbin/apache2 -k start
2689 clamav 130776 kB /usr/sbin/clamd
11587 www-data 96036 kB /usr/sbin/apache2 -k start
11575 root 66192 kB /usr/share/webmin/virtual-server/lookup-domain-daemon.pl
2469 bind 64864 kB /usr/sbin/named -u bind
7937 root 46608 kB /usr/share/webmin/proc/index_size.cgi
912 root 40728 kB python /usr/sbin/denyhosts --daemon --config=/etc/denyhosts.conf --config=/etc/d …
2975 root 40072 kB dovecot-auth
3017 root 38064 kB /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
3013 root 34472 kB /usr/bin/perl /usr/share/usermin/miniserv.pl /etc/usermin/miniserv.conf
2884 root 32544 kB /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5
2885 root 32544 kB /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5
2886 root 32544 kB /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5
2888 root 32544 kB /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5
2889 root 32544 kB /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5
2773 clamav 28456 kB /usr/bin/freshclam -d --quiet
2894 root 25844 kB /usr/sbin/sshd
3012 postfix 21832 kB tlsmgr -l -t unix -u -c
2872 postfix 20692 kB qmgr -l -t fifo -u
7045 postfix 20652 kB pickup -l -t fifo -u -c
2865 root 19616 kB /usr/lib/postfix/master
2963 root 11496 kB /usr/sbin/cron
1439 root 10592 kB udevd --daemon
2523 root 10112 kB /bin/sh /usr/bin/mysqld_safe
602 dovecot 8920 kB imap-login
28524 dovecot 8916 kB imap-login
9433 dovecot 8916 kB imap-login
31854 dovecot 8772 kB imap-login
6431 dovecot 8772 kB imap-login
7219 dovecot 8768 kB imap-login
1459 dovecot 8764 kB pop3-login
2838 dovecot 8764 kB pop3-login
3072 dovecot 8760 kB pop3-login
2935 root 7216 kB /usr/sbin/dovecot
1 root 6124 kB init [2]
7070 root 3728 kB /sbin/syslogd
3034 root 2656 kB /sbin/getty 38400 tty1
3040 root 2656 kB /sbin/getty 38400 tty5
3041 root 2656 kB /sbin/getty 38400 tty6
7075 root 2656 kB /sbin/klogd -x
2675 root 2652 kB /usr/sbin/acpid -c /etc/acpi/events -s /var/run/acpid.socket
3036 root 2652 kB /sbin/getty 38400 tty2
3037 root 2652 kB /sbin/getty 38400 tty3
3038 root 2652 kB /sbin/getty 38400 tty4
2561 root 2636 kB logger -p daemon.err -t mysqld_safe -i -t mysqld
1801 www-data 1636 kB /usr/sbin/apache2 -k start
2 root 0 kB [migration/0]
3 root 0 kB [ksoftirqd/0]
4 root 0 kB [watchdog/0]
5 root 0 kB [migration/1]
6 root 0 kB [ksoftirqd/1]
7 root 0 kB [watchdog/1]
8 root 0 kB [events/0]
9 root 0 kB [events/1]
10 root 0 kB [khelper]
11 root 0 kB [kthread]
16 root 0 kB [kblockd/0]
17 root 0 kB [kblockd/1]
18 root 0 kB [kacpid]
122 root 0 kB [khubd]
124 root 0 kB [kseriod]
176 root 0 kB [pdflush]
177 root 0 kB [pdflush]
178 root 0 kB [kswapd0]
179 root 0 kB [aio/0]
180 root 0 kB [aio/1]
423 root 0 kB [xfslogd/0]
424 root 0 kB [xfslogd/1]
425 root 0 kB [xfsdatad/0]
426 root 0 kB [xfsdatad/1]
464 root 0 kB [ata/0]
465 root 0 kB [ata/1]
466 root 0 kB [ata_aux]
496 root 0 kB [scsi_eh_0]
497 root 0 kB [scsi_eh_1]
498 root 0 kB [scsi_eh_2]
499 root 0 kB [scsi_eh_3]
1198 root 0 kB [kmirrord]
1253 root 0 kB [kjournald]
1761 root 0 kB [kpsmoused]
2786 root 0 kB [kondemand/0]
2787 root 0 kB [kondemand/1][/code:1]
here’s a screenshot of the traffic so you can visualize what i mean… thanks for any advice/help… i really appreciate it! i’d hate having to reinstall the system from scratch (and then possibly run into the same problems again)
