Hi People,
Suddenly and without any warning I find that the server is running very slow and I see that clamd.virtualmin -c /etc/clamd.d/virtualmin.conf is using 99% of the processor.
This server is very lightly loaded and handles about 100 emails per day.
I have read loads of posts about clamscan, clamd and clanc but can’t really say that I understand what is happening so perhaps I need some hand-holding with this. (sorry !)
When I look at “system Information” page (the one that shows immediately upon login) it says :-
Running processes 137
CPU usage 20% user, 5% kernel, 0% IO, 75% idle
If I click “Refresh system information” the page never seems to update, If I exit and re-enter the server it shows the same CPU usage but maybe one extra or less process running.
The server showed two packages to update (tzdata-java and tzdata) I updated them but the system Information page shows them still to update. If I try to update I get the error/warning that all is up to date.
CentOS Linux 5.11
Webmin version 1.821
Virtualmin version 5.04
Kernel and CPU Linux 2.6.18-412.el5 on x86_64
I have another server of very similar spec showing the same.
Any help would be well appreciated.
Thanks for reading,
Tim
