Then in Virtualmin/Subdomain/Logs and Reports/ Check Connectivity I get:
Nameserver lookup failed
Could not find any nameservers for subdomain.example.com
Check that your DNS domain has been registered.
The DNS record for example.com has the subdomain info added.
Is it missing something? The main domain and all other domains seem fine. The subdomain is accessible in a browser. What is messed up in the DNS setup?
$ttl 20M
@ IN SOA ns1.example.net. hostmaster.example.net. (
2009063024
2H
1H
1W
20M )
@ IN NS ns1.example.net.
@ IN NS ns2.example.net.
example.com. IN A xx.xx.xx.xx
www.example.com. IN A xx.xx.xx.xx
ftp.example.com. IN A xx.xx.xx.xx
localhost.example.com. IN A 127.0.0.1
mail.example.com. IN A xx.xx.xx.xx
example.com. IN MX 5 mail.example.com.
example.com. IN TXT "v=spf1 a mx a:example.com ip4:xx.xx.xx.xx -all"
subdomain.example.com. IN A 74.63.2.190
www.subdomain.example.com. IN A xx.xx.xx.xx
ftp.subdomain.example.com. IN A xx.xx.xx.xx
m.subdomain.example.com. IN A xx.xx.xx.xx
localhost.subdomain.example.com. IN A 127.0.0.1
webmail.subdomain.example.com. IN A xx.xx.xx.xx
admin.subdomain.example.com. IN A xx.xx.xx.xx
subdomain.example.com. IN MX 5 mail.subdomain.example.com.
if the connectivity checker is looking for ns records then it would come up with his warning. you have A records for the sub server. your ns records are .net and the domain is .com
I don’t think there is a problem with the subserver, just a “shortcoming” of the checker
When I check at squishy for ns record for the subdomain I also get an error (listed below) so I am worried that it is not the checker in Virtualmin but a problem with my record. it it normal for a subdomain to get this error?
My question is:
Since the main domain has ns records in the DNS record do sub servers require their own ns record?
subdomain IN NS ns1.example.net.
subdomain IN NS ns2.example.net.
Response is:
100.0% yy.yy.yy.yy (ns2.example.net) with no such record
Response is:
50.0% yy.yy.yy.yy (ns2.example.net) with no such record
50.0% xx.xx.xx.xx (ns1.example.net) with no such record
