navigate to virtualmin -> modul config -> under category: Advanced Options, i found Allow creation of sub-domains?. What is exactly different betwen sub domain & sub server on virtualmin ?
Can i change subserver base directory from /home/$user/domains to /home/$user/whatever ?
The sub-domain feature was an old feature that existed in Virtualmin that, really, is just a confusing way of doing things and was removed from everything but the advanced options. If you hadn’t gotten used to it being there in the past, I’d try to ignore it
If you want a sub-domain, no problem, just create a new Virtual Server, and when asked for the domain name to use, enter the sub-domain to use in the domain name field.
I don’t know of a way to do that, unfortunately… I think it needs to be in a sub-directory such as “domains”. I at one point thought there was a way to change the name “domains” to something else, but I’m not seeing a way to change that ATM
