Subdomain DNS using local IP
Given: Domain with DNS configured with external IP address
Problem: When creating a subdomain, the DNS records are created using the INTERNAL IP addess, instead of the same EXTERNAL IP address of the parent domain.
I can’t seem to find anywhere from which it would be pulling the internal IP.
You can set all that up by going into System Settings -> Module Config -> Network Settings.
You’d want to tweak “Default IP address for DNS records”.
Excellent, thanks for the direct help.
