I have a parent server(jope.ee) with couple of sub-servers, the problem is that some of them work, and some don’t. I’m using GPL version
For example sub-servers cod4.jope.ee, cod2.jope.ee and cod.jope.ee aren’t working, therefore sub-servers tf2.jope.ee and foorum.jope.ee are working. What could be the reason?
I’m not going to waste, so I’ll put my another problem here. When I create a server, the zone files aren’t transferred to slave DNS server.
Help would be highly appreciated.
Edit:
Now I noticed, that the sub-server cod4.jope.ee can be accessed with www in front of it. So
www.cod4.jope.ee works and cod4.jope.ee doesn’t. And again cod2 subdomain doesn’t work eighter way.
I’d recommend checking the logs on the master and the slave, to see if there’s any permissions issues going on during the transfer. It could be a port being blocked (via iptables), or perhaps a BIND setup issue where the IP or your slave isn’t setup to be allowed to transfer the zone files.
Well, all kinds of logging should already be enabled.
What I’d do is start poking around in your log files in /var/log – which ones exactly depends on the distro you’re using, but I might start in /var/log/messages. Restart BIND on both servers, and then peek in there to see if you notice any errors showing up.
