I recently joined the virtualmin community and I already need some help from you guys.
I installed a fresh centos 5.4 and then the virtualmin install script and everything went well. WOW
I created my virtual servers thanks to the virtualmin panel for my domain.com.
Currently, I’m not using BIND server as i’m using the servername of my registar which is enough for my 4 website which i want to settle on this server for the moment.
I created a subdomain at my “registar sever name” called webmail.mydomain.com
I would like now, to set the subdomain, on my apache server/virtualmin panel. How to do it easily thanks to the virtualmin panel or apache webmin panel ?
I found a option the advanced panel, System Settings -> Module Config -> Advanced Options -> Allow creation of sub-domains.
Is it the good way to do sub domain creation and management ?
FYI:
I checked my httpd.conf and i saw that there is a rewrite url rules which say:
RewriteCond %{HTTP_HOST} =webmail.mydomain.com
RewriteRule ^(.*) https://mydomain.com:20000/ [R]
Do I need to remove this rules ?
And
Do I need to remove also the “webmail.mydomain.com” subsitute name on the network & address panel ?
Thanks in advance for your help again.
