I notice that sub-domain functions are very limited.
For example, I can enable Mysql databases, but cant edit the list of databases.
For example, I cannot add scripts to a subdomain.
This for a reason? Or a future fix?
Thanks!
John P.
Thanks!
John P.
Hey John,
This is all merely configuration. You can modify all of these details in the Server Templates for sub-servers.
The “Default domain owner limits” section is the one you’re looking for, and the options are “Can manage databases” and “Can install scripts”
So, there’s no reason for it, and nothing to fix.
