I was looking to buy for a SuSE 10.0 OS and could not find it in the style selection in the shopping module. Which style should I select to get this style.
Thank you,
Delta
Thank you,
Delta
Oops… I just noticed that the store doesn’t know about SUSE yet, despite it being supported by the installer.
I will add it. In the meantime, you can choose any of the Operating Systems listed–the download is the same. We’re just trying to keep some numbers on who is using what OS, so we know where to spend our time.
Thanks for the heads up!
BTW-Let us know of any problems you run into. I think you’ll be the first real SUSE user. And be fairly warned, there will be problems…if you need it to be perfect, wait until the Early Adopter period is over!
