Strange quota calculations
Hi
First of all, thanks for all the work that has gone into Virtualmin, I am a new user but loving it already.
Today I stumbled across a strange quota calculation for one of my domains, basically it reports the following:-
[li]Home disk space used (including sub-servers) 9.68 MB (10.25 MB by server administrator, 151.54 MB by mail / FTP users)[/li] [li]Space used by databases 88 kB (88 kB in this server, 0 bytes in sub-servers)[/li] [li]Total disk space used 9.77 MB[/li]
All other domains appear to be correct, I have tried refreshing but it does not make any difference.
Any ideas? Any pointers would be appreciated.
Paul
Heh! That doesn’t sound right, does it.
What distribution are you using? And which Virtualmin version is that?
Thanks!
Sorry, I should have provided that info to start with.
Running:
[li]Virtualmin 3.66.gpl[/li]
[li]Ubuntu Linux 8.04.2[/li]
This is on a VPS if that is of any significance?
Pau
Okay, nothing is standing out to me there as a cause of the issue.
Yeah, it’s always good to know when you’re on a VPS, though I don’t think that’s a cause of the issue here.
Here’s what I would do – since that sounds a bit “bug-like”, as Joe would say, I’d recommend filing a bug report about that so Jamie can take a peek.
If it’s not a bug, he’ll help point us in the right direction as to how to resolve it.
Thanks!
Ok, will file the report now!
Paul
