i am using the latest virtualmin pro, but the script there is no compatible php version but i have on the server php 8.1.12 and is telling no compatible php version found
strange, something wrong with virtualmin?
thank you
Virtualmin installs the default PHP version that ships with the OS.
It is possible to manually install additional PHP versions (and that often is necessary, especially on a shared server), but you have to set that up yourself. If done properly, they’ll all show up in Virtualmin and will be available to whatever script or site needs them.
The exact procedure varies with the OS. The link above looks pretty current.
