Virtualmin Professional is installed, latest version.
Dear all, I got the following email from my cron daemon:
date: Sun, May 11, 2008 at 6:25 AM
subject: Cron <root@poseidon> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
/etc/cron.daily/logrotate:
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
httpd not running, trying to start
error: error running postrotate script for /home/virtualserver1.com/logs/access_log
Unable to open logs
error: error running postrotate script for /home/virtualserver1.com/logs/error_log
Unable to open logs
error: error running postrotate script for /home/virtualserver2.com/logs/access_log
Unable to open logs
error: error running postrotate script for /home/virtualserver2.com/logs/error_log
Unable to open logs
error: error running postrotate script for /home/virtualserver3.com/logs/access_log
Unable to open logs
error: error running postrotate script for /home/virtualserver3.com/logs/error_log
Unable to open logs
error: error running postrotate script for /home/virtualserver4.com/logs/access_log
Unable to open logs
error: error running postrotate script for /home/virtualserver4.com/logs/error_log
run-parts: /etc/cron.daily/logrotate exited with return code 1
Does anyone have any idea what this is all about?
My apache server runs to port 80 on all IPs (at least now it does):
netstat -pan
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2530/apache2
However the /var/log/apache/error.log file starts at exactly that time:
/var/log/apache2) $ cat error.log
[Sun May 11 06:25:09 2008] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
Also many log files start at this time:
syslog: May 11 06:25:09 poseidon syslogd 1.4.1#18: restart.
messages: May 11 06:47:01 poseidon syslogd 1.4.1#18: restart.
Also all .0 log files not zipped:
auth.log.0, dmesg.0 …
However nothing indicates a system reboot…
Could this be a breach…all help deeply appreciated…
P.S: Why logrotate (or is it something else ???) needs to bind to port 80?
