yesterday i had a strange error for the 3rd time in the past 6 months or so. it looks like this : https://www.virtualmin.com/node/10374
but what happens is that main.cf in postfix loses 90 lines (from 60-150) of configuration from main.cf (!?)
for example (main.cf.bkp is yesterday’s corrupt main.cf) :
wc -l main.cf
239 main.cf
wc -l main.cf.bkp
149 main.cf.bkp
diff main.cf.bkp main.cf
51c51
< smtp_tls_security_level = dane
smtp_tls_security_level = may
58c58
< smtpd_tls_security_level = may
60a61,151
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3
smtpd_tls_ciphers=high
smtpd_tls_mandatory_ciphers = high
smtpd_tls_exclude_ciphers=aNULL,aDH,MD5
smtpd_tls_mandatory_exclude_ciphers=aNULL,aDH,MD5
smtpd_tls_security_level = mayTLS policy map
smtp_tls_CApath = /etc/ssl/certs
smtp_tls_policy_maps = hash:/etc/postfix/tls_policy
smtp_tls_fingerprint_digest = sha1
smtpd_tls_CApath = /etc/ssl/certs
smtp_tls_protocols = !SSLv2,!SSLv3
smtp_tls_exclude_ciphers = aNULL,aDH,MD5
smtp_tls_mandatory_exclude_ciphers = aNULL,aDH,MD5Log TLS handling
smtpd_tls_loglevel = 1
smtp_tls_loglevel = 1Enable elliptic curve cryptography, “ultra” needs more cpu time
smtpd_tls_eecdh_grade = strong
myhostname = $server
#myorigin = /etc/mailname
mydestination = $server, localhost
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
home_mailbox = Maildir/
smtpd_sasl_auth_enable = yes
broken_sasl_auth_clients = yesRequirements for the HELO statement
smtpd_helo_restrictions =
permit_mynetworks,
warn_if_reject,check_helo_access pcre:/etc/postfix/helo_checks.pcre,
check_helo_access hash:/etc/postfix/access,
reject_invalid_hostname,
permitRequirements for the sender details
smtpd_sender_restrictions =
permit_mynetworks,
check_sender_access hash:/etc/postfix/sender_access,
reject_non_fqdn_sender,
reject_unauth_pipelining,
reject_unlisted_sender,
reject_unknown_sender_domain,
permit#smtpd_recipient_restrictions = permit_mynetworks permit_sasl_authenticated reject_unauth_destination check_policy_service inet:127.0.0.1:12345
permit_mynetworks,
permit_sasl_authenticated,
check_client_access hash:/etc/postfix/access,
reject_non_fqdn_hostname,
reject_non_fqdn_recipient,reject_unknown_sender_domain,
reject_unknown_recipient_domain,
reject_unknown_reverse_client_hostname,
reject_unknown_helo_hostname,
reject_unauth_destination,
reject_rbl_client zen.spamhaus.org,reject_rbl_client bl.mailspike.net,
reject_rbl_client backscatter.spameatingmonkey.net,
reject_rbl_client cbl.abuseat.org,
reject_rbl_client dnsbl.dronebl.org,
reject_rbl_client ix.dnsbl.manitu.net,
reject_rbl_client rbl.void.gr,
reject_rbl_client list.dsbl.org,
reject_rbl_client dul.dnsbl.sorbs.net,
reject_rhsbl_client blackhole.securitysage.com,
reject_rhsbl_client dsn.rfc-ignorant.org,
reject_rhsbl_sender blackhole.securitysage.com,
check_policy_service unix:/var/spool/postfix/postgrey/socket,
check_policy_service inet:127.0.0.1:12345,
permit
any relative log entries found :
miniserv.error :
restarting miniserv
[21/Mar/2018:13:06:34 +0200] Restarting
Pre-loaded virtual-server/virtual-server-lib-funcs.pl in virtual_server
Pre-loaded virtual-server/feature-unix.pl in virtual_server
Pre-loaded virtual-server/feature-dir.pl in virtual_server
Pre-loaded virtual-server/feature-dns.pl in virtual_server
Pre-loaded virtual-server/feature-mail.pl in virtual_server
Pre-loaded virtual-server/feature-web.pl in virtual_server
Pre-loaded virtual-server/feature-webalizer.pl in virtual_server
Pre-loaded virtual-server/feature-ssl.pl in virtual_server
Pre-loaded virtual-server/feature-logrotate.pl in virtual_server
Pre-loaded virtual-server/feature-mysql.pl in virtual_server
Pre-loaded virtual-server/feature-postgres.pl in virtual_server
Pre-loaded virtual-server/feature-ftp.pl in virtual_server
Pre-loaded virtual-server/feature-spam.pl in virtual_server
Pre-loaded virtual-server/feature-virus.pl in virtual_server
Pre-loaded virtual-server/feature-webmin.pl in virtual_server
Pre-loaded virtual-server/feature-virt.pl in virtual_server
Pre-loaded virtual-server/feature-virt6.pl in virtual_server
[21/Mar/2018:13:06:37 +0200] miniserv.pl started
[21/Mar/2018:13:06:37 +0200] Using MD5 module Digest::MD5
[21/Mar/2018:13:06:37 +0200] Using SHA512 module Crypt::SHA
[21/Mar/2018:13:06:37 +0200] PAM authentication enabled
deleting and
Use of uninitialized value $minsize in numeric lt (<) at /usr/share/webmin/acl/acl-lib.pl line 1764.
Use of uninitialized value in split at /usr/share/webmin/acl/acl-lib.pl line 1767.
Error: No virtual domains file (virtual_alias_maps) was found in your Postfix configuration!
[21/Mar/2018:14:31:32 +0200] Reloading configuration
after that time (13:06), main.cf was missing its configuration and you can see the diff of the files above. untill 14:31. at that point we restored an original main.cf from backup and reloaded postfix.
mail.err :
Mar 21 13:06:41 server dovecot: master: Fatal: Dovecot is already running with PID 1490 (read from /var/run/dovecot/master.pid)
Mar 21 13:07:28 server postfix/local[13682]: fatal: main.cf configuration error: mailbox_size_limit is smaller than message_size_limit
Mar 21 13:08:29 server postfix/local[13997]: fatal: main.cf configuration error: mailbox_size_limit is smaller than message_size_limit
Mar 21 13:09:30 server postfix/local[14522]: fatal: main.cf configuration error: mailbox_size_limit is smaller than message_size_limit
Mar 21 14:24:45 server postfix/local[6297]: fatal: main.cf configuration error: mailbox_size_limit is smaller than message_size_limit
Mar 21 14:25:46 server postfix/local[8188]: fatal: main.cf configuration error: mailbox_size_limit is smaller than message_size_limit
Mar 21 14:26:47 server postfix/local[8453]: fatal: main.cf configuration error: mailbox_size_limit is smaller than message_size_limit
mail.log entry :
Mar 21 13:06:50 server postfix/smtp[13189]: 582872A1A9AC: to=user@domain, relay=none, delay=0.18, delays=0.16/0/0.01/0, dsn=5.4.6, status=bounced (mail for domain loops back to myself)
using fully upgraded debian 9, latest webmin and virtualmin gpl. amd64 arch.
any ideas on what could cause this?
thanks,
(and sorry for the long post)
