EDIT: (for better explanation)
I have two servers, both running the same version of Ubuntu 12.04. both running vanilla virtualmin installations;
I have backed up all sites from server A and moved to server B
upon recreation, the default website seems to be pointing to an alias of site 1 ( site1= appsrv, alias = svn)
after deletion of svn.mywebsite.org, the default site seems to still point to svn.mywebsite.org, and for some reason on port :20000 for usermin
strangely enough, the original server didnt even have usermin. ever stranger ALL the virtual hosts ARE WORKING besides the default ??
i deleted the record virtual host for svn.mywebsite org, and reset the default site to appsrv.mywebiste.org, but nothing changed, it still is redirecting to svn.mysite.org:10000
i have restarted the machine, double checked the virtual hosts in sites-enabled… i have even changed each one so that the virtulhost tag had a * instead of the local ip… nothing. except, when i do this for each site, the Next site becomes to default. if all are changed to * in the virtualhost tag, then none of the virtualhosts work, and all redirect to usermin
this has totally baafflled me, and require some help. please and thank you in advance!
