Well,
with a fresh install of Virtualmin, installation of Samba and using letsencrypt cert under Debian 9.3, i had a lockup of webmin. After restart it keeps saying:
– Unit webmin.service has begun starting up.
Jan 08 10:16:25 server05 perl[24653]: pam_unix(webmin:auth): authentication failure; logname= uid=0 euid=0 tty= ruse
Jan 08 10:16:26 server05 systemd[1]: webmin.service: Control process exited, code=exited status=2
Jan 08 10:16:26 server05 systemd[1]: Failed to start LSB: web-based administration interface for Unix systems.
– Subject: Unit webmin.service has failed
– Defined-By: systemd
– Support: https://www.debian.org/support
– Unit webmin.service has failed.
– The result is failed.
Jan 08 10:16:26 server05 systemd[1]: webmin.service: Unit entered failed state.
Jan 08 10:16:26 server05 systemd[1]: webmin.service: Failed with result ‘exit-code’.
lines 1329-1351/1351 (END)
Jan 08 10:14:49 server05 sshd[24617]: Failed password for root from 58.218.198.159 port 53732 ssh2
Jan 08 10:14:51 server05 sshd[24617]: Failed password for root from 58.218.198.159 port 53732 ssh2
Jan 08 10:14:51 server05 sshd[24617]: Received disconnect from 58.218.198.159 port 53732:11: [preauth]
Jan 08 10:14:51 server05sshd[24617]: Disconnected from 58.218.198.159 port 53732 [preauth]
Jan 08 10:14:51 server05 sshd[24617]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=58.218.198.159 user=root
Jan 08 10:16:25 server0 systemd[1]: Starting LSB: web-based administration interface for Unix systems…
– Subject: Unit webmin.service has begun start-up
Jan 08 10:16:25 server05 perl[24653]: pam_unix(webmin:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost= user=root
with the command
service webmin start
with
/etc/init.d/webmin start
i will get no error, but it won’t run either.
Any help truly appreciated, latest virtualmin (installed Thursday last week with wget from virtualmin.com)
Thanks and best
j_m
PS: i checked around in this website and with google, but none of the idea’s really seemed to work. Found that one: https://www.virtualmin.com/node/53188 which is on CentOS, but don’t gives me any idea, how to be able to start virtualmin at all.
