Starting ProFTPD in Webmin displays an error
Hey, when I try to start ProFTPD in webmin it displays the following message:
Job for proftpd.service failed because the control process exited with error code. See “systemctl status proftpd.service” and “journalctl -xe” for details..
When i enter systemctl status proftpd.service i get the following:
proftpd.service - ProFTPD FTP Server
Loaded: loaded (/usr/lib/systemd/system/proftpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Wed 2019-12-11 12:57:45 EET; 15min ago
Process: 15524 ExecStart=/usr/sbin/proftpd $PROFTPD_OPTIONS (code=exited, status=1/FAILURE)
Dec 11 12:57:45 test2.loc systemd[1]: Starting ProFTPD FTP Server…
Dec 11 12:57:45 test2.loc proftpd[15524]: 2019-12-11 12:57:45,361 test2.loc proftpd[15524]: fatal: : relative path not allowed in non- sections on line 356 of ‘/etc/proftpd.conf’
Dec 11 12:57:45 test2.loc systemd[1]: proftpd.service: control process exited, code=exited status=1
Dec 11 12:57:45 test2.loc systemd[1]: Failed to start ProFTPD FTP Server.
Dec 11 12:57:45 test2.loc systemd[1]: Unit proftpd.service entered failed state.
Dec 11 12:57:45 test2.loc systemd[1]: proftpd.service failed.
And when I enter the file and navigate to the line 356 and surrounding I see this info:
# Allow users to overwrite files and change permissions
AllowOverwrite on
AllowAll
<Directory <>
DefaultRoot ~
DefaultRoot ~
DeleteAbortedStores on
Perhaps you can help me.
