SSL Setup Issue
When I input a signed ssl certificate (positiveSSL) I get the message: “Failed to install certificate : Missing or invalid signed SSL certificate : Data does not start with line -----BEGIN CERTIFICATE-----” However, it 100% starts with ----Begin Certificate----. What is going on?
Linux usually is case sensitive, so BEGIN != Begin.
If “PossitiveSSL” generates certificates for you that have “Begin Certificate” in the header line, you should fix that manually, and then drop them a note that they should fix their odd generation process.
My certificate begins with:
And virtualmin displays the error: Failed to install certificate : Missing or invalid signed SSL certificate : Data does not start with line -----BEGIN CERTIFICATE-----.
Is there anyway around this? I’ve tried it several times now – with new CSR’s, delete/re-add virtual server, ect. Nothing is working. I can give access.
-Calvin
Another fellow ran into that recently… check out the solution he mentions at the end of this thread here:
https://virtualmin.com/node/24608
Thanks, I’ll give that a try! I bet that’s probably the culprit because everything else is right…I’ll update this post once I get the new cert in ~30 minutes.
