I’m currently trying to install a SSL cert for a client on his website. They have bought the cert from 1 2 3 reg using their CSR generation tool.
when I go to install the new cert and private key I get the following error:
Failed to install certificate : Missing or invalid signed SSL certificate : Data does not start with line -----BEGIN CERTIFICATE-----
I’ve tried adding the CA as well but I get the following error:
Failed to save CA certificate : Invalid certificate file : unable to load certificate 3078383340:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:703:Expecting: TRUSTED CERTIFICATE
Any help will be much appreciated. I know I haven’t really explained much so if anymore info is needed I can supply it.
