Hi guys,
I have install Centos7 & Webmin/Virtualmin
CentOS Linux 7.8.2003
Webmin version 1.942
One server (main hostname) gets SSL without any problem. Anyway, for another Virtual Server I can’t setup SSL. This is output
Requesting a certificate for domainname, www.domainname from Let’s Encrypt …
… request failed : Web-based validation failed : Failed to request certificate :
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 198, in
main(sys.argv[1:])
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 143, in get_crt
raise ValueError(“Wrote file to {0}, but couldn’t download {1}: {2}”.format(wellknown_path, wellknown_url, e))
ValueError: Wrote file to /home/user/public_html/.well-known/acme-challenge/gTCol2NPIQOSPcstDAk6ysEEbTsiyfytBmayhW8EbsU, but couldn’t download http://domainname/.well-known/acme-challenge/gTCol2NPIQOSPcstDAk6ysEEbTsiyfytBmayhW8EbsU: Error:
Url: http://domainname/.well-known/acme-challenge/gTCol2NPIQOSPcstDAk6ysEEbTsiyfytBmayhW8EbsU
Data: None
Response Code: None
Response: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:618)>
, DNS-based validation failed : Failed to request certificate :
usage: acme_tiny.py [-h] --account-key ACCOUNT_KEY --csr CSR --acme-dir
ACME_DIR [–quiet] [–disable-check]
[–directory-url DIRECTORY_URL] [–ca CA]
[–contact [CONTACT [CONTACT …]]]
acme_tiny.py: error: argument --acme-dir is required
