Requesting a certificate for sketchvibes.in, *.sketchvibes.in from Let’s Encrypt …
… request failed : Web-based validation failed : Wildcard hostname *.sketchvibes.in can only be validated in DNS mode
how to fix it?
how to fix it?
In Server Configuration > SSL Certificate > Let's Encrypt
, make sure you untick Also request wildcard certificate?
before requesting the certificate.
If you have any subdomains that you want to request a certificate for, just add them along with the top domain in the Domain names listed here
section.
But if you really need a wildcard certificate, then as @Ilia mentioned in this thread, you will need to host DNS locally.
make sure you set your DNS correctly in your virtualmin and registar
