ssl installation in virtualmin
hello.
i want to install ssl in my virtualmin so buy new ssl from comodo
install successfully but still not able to access https:// address with site can anyone help here ??
What happens when you try to access the https:// site? Do you receive an error of some kind?
When i try to access https:// its load page long time and gives white page
It sounds like there may be a firewall of some kind blocking access to port 443.
Is your server running a firewall?
Or is there maybe a firewall/router in front of your server that’s either blocking that port, or not performing port forwarding?
no i have no firewall install on server
also i used this code for this:
iptables -A INPUT -p tcp --dport 443 -j ACCEPT
/sbin/service iptables save
iptables -L -v
i did check all my setting , everything working fine still not able to connect with https:// address any update ??
Hello ,
I solved the above problem , that was CloudFlare which were blocking to connect https:// as they not provide ssl service for free plan , after switching off cloudflare its worked !!!
i have a additional question … site working with https://www.domain.com not with https://domain.com any idea ??
see attachment file *
If you switched off cloudflare, it could just be DNS hasn’t fully updated yet. I would double check the DNS records exists (A records) and are properly configured.
