SSL Certs "Copy to function"
So I copied all Certs to all available options. Virtualmin reports: “This SSL certificate is already being used by : Postfix, Usermin, Webmin”
Why is Dovecot not listed? Even though it also uses the Cert. No matter how often I click “Copy to Dovecot” it reports success but the button remains…
I want it to list dovecot in the list and the button to disappear.
There’s a bug report on that issue here, I’d suggest following up in that bug report and explaining the issue you are seeing:
http://virtualmin.com/node/32574
