Hi.
If I apply one of the domain’s certificates to dovecot or PostFix,
Server configuration > Mange SSL Certificates > Copy to Dovecot / PostFix,
The certificate is copied to the server itself. root/etc/Dovecot|Postfix
At the same time, when you do this, all the other domains stop from being able of retrieving emails.
To fix it, I have to manually restart dovecot.
What am I doing wrong?
If this is a feature , perhaps this feature should not be in the virtualmin domain section but in the webmin area. Wouldn’t you think so?
I just copied the key and certificate files to a directory and set them up manually using the dovecot/postfix webmin bits. It would be nice if there was an easy way of telling when they expire from there though.
mk, could you kindly elaborate on how you “set them up manually using the dovecot/postfix webmin bits”?
In Webmin > Servers > Postfix > SMTP Authentication And Encryption I don’t see any option to assign diff. certs to diff. hosts (“Virtual Servers”).
Where did you manage to do this?
Am I missing something or is this a feature, that still needs to be added to virtualmin, considering virtually everything is working for virtual domains, except the ssl certs?
