SSL Certificate Request Problem
$ sudo tail -f /var/log/letsencrypt/letsencrypt.log
File “/usr/lib/python3/dist-packages/certbot/_internal/client.py”, line 496, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, self.config, best_effort)
File “/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py”, line 108, in handle_authorizations
self._poll_authorizations(authzrs, max_retries, max_time_mins, best_effort)
File “/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py”, line 212, in _poll_authorizations
raise errors.AuthorizationError(‘Some challenges have failed.’)
certbot.errors.AuthorizationError: Some challenges have failed.
2024-11-03 08:42:57,364:ERROR:certbot._internal.log:Some challenges have failed.
please anyone help me,
how can i go about it
it looks like a lookup problem for the domain.
lets encrypt can not find the ip for this host.
what says nslookup ?
I was checking when you posted … the hostname does not resolve the OP needs to fix that
But i can see that my domain has already propagate
When i run
nslookup domain >>>>>>>> it return my server-IP
I’m guess you are trying to get a certificate for
boa.verify.secure-verifybnk.net
that does not resolve
and also
does not resolve but
does
where are you managing your DNS ?
I registered the domain in
nicenic
And by way the domain should look like this
boa-verify.secure-verifybnk.net
Not
Ok typo … but google has marked your site as dangerous perhaps fix that then worry about ssl certificate when the domain is clean
the domain is a clean domain dont know what google really want,
i just bought the domain today, and not site pages on it yet.
Maybe it was used before something bad and google is unaware that there is a change in ownership and content, never having that problem I’m not sure on the best course of action. Is there any content on the site or just the default virtualmin page ?
just default virtualmin page
Just because the IP/domain has propagated for you it does not mean that the lets encrypt servers will see that change at the same time as you. I made this mistake a few times.
Also TTL (time to live) can play a part.
