| SYSTEM INFORMATION | |
| OS type and version | REQUIRED |
| Virtualmin version | REQUIRED |
I have recently moved from my own nameservers to use the default IONOS nameservers. Ever since, my ssl certificate refuses to renew quoting:
Requesting a certificate for xsxtc.uk, www.xsxtc.uk, mail.xsxtc.uk, admin.xsxtc.uk, webmail.xsxtc.uk from Let’s Encrypt ..
.. request failed : Web-based validation failed : Failed to request certificate :
File “/usr/share/webmin/webmin/acme_tiny.py”, line 198, in
main(sys.argv[1:])
File “/usr/share/webmin/webmin/acme_tiny.py”, line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/share/webmin/webmin/acme_tiny.py”, line 121, in get_crt
order, _, order_headers = _send_signed_request(directory[‘newOrder’], order_payload, “Error creating new order”)
File “/usr/share/webmin/webmin/acme_tiny.py”, line 60, in _send_signed_request
return _do_request(url, data=data.encode(‘utf8’), err_msg=err_msg, depth=depth)
File “/usr/share/webmin/webmin/acme_tiny.py”, line 46, in _do_request
raise ValueError(“{0}:\nUrl: {1}\nData: {2}\nResponse Code: {3}\nResponse: {4}”.format(err_msg, url, data, code, resp_data))
ValueError: Error creating new order:
Url: https://acme-v02.api.letsencrypt.org/acme/new-order
Data: b’{“protected”: “eyJ1cmwiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvbmV3LW9yZGVyIiwgImFsZyI6ICJSUzI1NiIsICJub25jZSI6ICJ4b1pmdVJmLVliVGYxRnVfb0RLdmQyT1hkeTYxRWlGMEhPUzJpNm1TckxwZklRUXUzRFkiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTYyNDk2NTcyNyJ9”, “payload”: “eyJpZGVudGlmaWVycyI6IFt7InR5cGUiOiAiZG5zIiwgInZhbHVlIjogImFkbWluLnhzeHRjLnVrIn0sIHsidHlwZSI6ICJkbnMiLCAidmFsdWUiOiAieHN4dGMudWsifSwgeyJ0eXBlIjogImRucyIsICJ2YWx1ZSI6ICJtYWlsLnhzeHRjLnVrIn0sIHsidHlwZSI6ICJkbnMiLCAidmFsdWUiOiAid3d3LnhzeHRjLnVrIn0sIHsidHlwZSI6ICJkbnMiLCAidmFsdWUiOiAid2VibWFpbC54c3h0Yy51ayJ9XX0”, “signature”: “sa338ANsslUdN9VQalgJLmsJmgoP3o3nW5NJRPxS88Fk2OM_s4XwznurxEMhcJr095U4eVsrh5rQJ6Ubev_hODMCR9oQJ7uQzIi9QzqZTrMdLM4msMFsOUSx9DfEFZ3ZoTYoroylzp0JnN4jmVJdgjo_7NZG4K0WgrzlqzlURXIv_p6Nk4rK8uu6du3Jr1bIKxL-XRa2S-Cy3TwdrCyFIkt1-mS4r9sgyhwrUuCOUiBRHn6SqJ4eHfj9Ook5zo9Q24cvmdzkZ9tuthIFD-nLxrrzRqa3hkvCGsYRNpnoJ_qaxasdsTvurIfzgio0_jnN-0F_OJpQKEDsx6Gj2fw7EFGKQiV3xWIIlT5eKwcd9CVB1Nu2cPiUhvkE5BbWAp7VaseRW880AIowBM373gBEzicftMqsB4omHasNDZPdrr2k3Z5mF0hsy6A84pKHRMhN8MIBM7ha_Of6Yco3iOoPLqGYufy7LJGtSYFfeuqp0L4NyumzH2vB345a_dIaaGLAsYU25DOcRJRihVhbUU5pEWUliiktKzZocq-tEWJoJcs3Tp3nmteIhAT3yvZM6KuHeciPAHMyJpb5XRBmfOYl2VdL23sVtKZlwRpwQIzvYxl0_z4KtdvlrHZkJGCCrgD8Z5ioKp5GGRf_MPxjsLL10OyIP_kUXG6lYNfdLKiXDWE”}’
Response Code: 429
Response: {‘type’: ‘urn:ietf:params:acme:error:rateLimited’, ‘detail’: ‘too many failed authorizations (5) for “admin.xsxtc.uk” in the last 1h0m0s, retry after 2026-05-17 08:47:11 UTC: see Rate Limits - Let's Encrypt’, ‘status’: 429}
DNS-based validation failed : Only the official Let’s Encrypt client supports DNS-based validation
I am in the middle of migrating to a new VPS so I would like to make sure I am not passing a problem over to the new setup.
I have reset the webmin ssl settings and that appeared to work fine. Yet the certificate will still not renew on either http or DNS validation.
Any suggestions?
