alexo
November 13, 2015, 8:55am
#1
Hello
Today i got SSL certificate and after installation i cann’t login into webmin/virtualmin = no access to this port 10000 from all browsers ()
Chrome
https://172.110.7 .***:10000/
This webpage is not available
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Firefox
Secure Connection Failed
An error occurred during a connection to 172.110.7.***:10000. Cannot communicate securely with peer: no common encryption algorithm(s). (Error code: ssl_error_no_cypher_overlap)
IE
Internet Explorer cannot display the webpage
the same is with domain.name
-but i have access to :20000 !!!
How can i restore my webmin access?
Is the problem with certificate or with webmin ?
Which files do i need to change to get access? (i have backups of this files miniserv.conf and miniserv.pem(
Any advice?
thank you !
Eric
November 13, 2015, 2:44pm
#2
You may want to start by taking a look at /etc/webmin/miniserv.conf. In there, do you see any lines that are restricting the available ciphers?
alexo
November 13, 2015, 4:17pm
#3
Here is miniserv.conf file
port=10000
root=/usr/libexec/webmin
mimetypes=/usr/libexec/webmin/mime.types
addtype_cgi=internal/cgi
realm=Webmin Server
logfile=/var/webmin/miniserv.log
errorlog=/var/webmin/miniserv.error
pidfile=/var/webmin/miniserv.pid
logtime=168
ppath=
ssl=1
no_ssl2=1
no_ssl3=1
env_WEBMIN_CONFIG=/etc/webmin
env_WEBMIN_VAR=/var/webmin
atboot=1
logout=/etc/webmin/logout-flag
listen=10000
denyfile=.pl$
log=1
blockhost_failures=5
blockhost_time=60
syslog=1
session=1
server=MiniServ/1.760
userfile=/etc/webmin/miniserv.users
keyfile=/etc/webmin/miniserv.pem
passwd_file=/etc/shadow
passwd_uindex=0
passwd_pindex=1
passwd_cindex=2
passwd_mindex=4
passwd_mode=0
preroot=virtual-server-theme
passdelay=1
cipher_list_def=1
sessiononly=/virtual-server/remote.cgi
preload=
anonymous=/virtualmin-mailman/unauthenticated=anonymous
mobile_preroot=virtual-server-mobile
mobile_prefixes=m. mobile.
ssl_cipher_list=ECDHE-RSA-AES256-SHA384:AES256-SHA256:AES256-SHA256:RC4:HIGH:MEDIUM:+TLSv1:+TLSv1.1:$
logouttimes=
Eric
November 13, 2015, 5:52pm
#4
Try commenting out the ssl_cipher_list line at the bottom, and then restart Webmin with this command:
/etc/init.d/webmin restart
After doing that, are you able to access Virtualmin?
-ERic
