hi there
i had to renew a wildcard ssl certificate issued by commodo last year. everything worked fine. after renewal of the certificate we experienced issues with certain mail-clients (postbox on apple, thunderbird) to access mail without warning that the certificate is not valid. furthermore firefox displays the following:
ourdomain.ch:10000 uses an invalid security certificate.
The certificate expired on 10/4/12 1:59 AM. The current time is 10/10/12 12:26 PM.
(Error code: sec_error_expired_certificate)
virtualmin tells me ( “Server Configuration” -> “Manage SSL Certificate”):
Web server hostname *.ourdomain.ch Issuer name EssentialSSL CA
Issuer organization COMODO CA Limited Expiry date Oct 4 23:59:59 2013 GMT
Certificate type Signed by CA
so what went wrong with the update? google chrome is showing things as correct. one difference i see to an other installation is the following:
a perfectly running virtualmin domain under -> “Server Configuration” -> “Manage SSL Certificate”
SSL certificate file /home/xyz/ssl.cert
SSL private key file /home/xyz/ssl.key
it shows me cert and key file location, on the updated server i do not see any of these information, why?
i don’t know what i have to do differently then when setting it first up, or maybe i missed something which i did and was not mentioned in the documentation.
any help what to do?
best
m
