My domain name geniuserver.info https:// Ssl certificate problem dont activated why ?
Requesting a certificate for geniuserver.info and 4 more domains
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
Domain: admin.geniuserver.info
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for admin.geniuserver.info - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for admin.geniuserver.info - check that a DNS record exists for this domain
Domain: mail.geniuserver.info
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for mail.geniuserver.info - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for mail.geniuserver.info - check that a DNS record exists for this domain
Domain: webmail.geniuserver.info
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for webmail.geniuserver.info - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for webmail.geniuserver.info - check that a DNS record exists for this domain
Domain: www.geniuserver.info
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.geniuserver.info - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.geniuserver.info - check that a DNS record exists for this domain
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
Some challenges have failed.
And read the Let’s Encrypt error report hat you have posted.
It mentions specific domain subdomain names which do not have DNS records. You need to go through the error report and address the issue by fixing the DNS records of your domain, as @Dibs has suggested.
You are requesting certificates for names that do not have records. Stop doing that.
Either add A records for the names you want certificates for, or remove the names you don’t want certificates for from your request. When you request the certificate, you are shown a list of names that will be included in the certificate, you can choose to not request all of the default Virtualmin domains, if you aren’t using them and haven’t created records for them in your DNS.
Virtualmin is obviously not managing your DNS. If you want Virtualmin to manage your DNS, you need to delegate authority for your zone to the Virtualmin server and a secondary DNS server that is configured as a slave to the Virtualmin server, or use one of the supported cloud DNS services and delegate authority to that.
If you will be hosting DNS elsewhere, you manage the DNS there.
Thank you in advance sir. Just you write as an answer but since I’m new I can’t fully understand. Is there a video or picture or what part of the problem I have can be captured so that we can find a solution to the problem?
No. Read this thread again, watch the video again. You’ve been told in multiple ways by multiple people how to solve the problem. Stop asking the same question over and over and do what we’ve told you to do:
Either fix your DNS to include A records for every name you are requesting a certificate for or don’t request certificates for missing domains.
