SSH keypair does not work, not password either when transfer domain
Webmin version 2.202
Virtualmin version 7.30.4
Webserver version Latest apache
I try to transfer a domain to new server.
I have created a ssh keypair and copied the .pub to the remote server but for some reason it does not work:
I can use password and it works using the terminal
When I try using password for the transfer I get this
Failed to transfer server : Failed to contact Virtualmin on destination system : root@184.174.32.123’s password: Permission denied, please try again. root@184.174.32.123’s password: Permission denied, please try again. root@184.174.32.123’s password: root@184.174.32.123: Permission denied (publickey,password)
Do you need to enable ssh for the root account. By default root on Ubuntu does not have ssh access I believe.
No its no problem logging in via ssh client with root/passwd. But that does not work for transfer. And the keypair does not work either
I have absolutely NO idea if this would/should make a difference. This question is to satisfy my own curiosity.
Do you have jail kit enabled?
If it asks for a password when you try to login from the terminal, it means you haven’t configured key authentication correctly, somewhere. ssh won’t ask for a password if it can authenticate with a key (unless the private key is password protected, I don’t think you can use a password-protected key, though, so I’d try one without).
Also, I would not recommend using the root account for backups! There’s no reason to do that, and it’s very dangerous to have root passwords or root keys floating around on a bunch of servers. You’re just using the server as a place to put backup files, you don’t need root access for that!
Thanks Joe for insight. Somehow I have solved it and I will change and not use root. for the backups. But it still strange that it did not work. A fresh server with Ubuntu 24 and nothing else.
