SPeed Up Domain
I have a server with 30 domains on it.
There appears to be plenty of resource capacity on the server, so I want dedicate more power, particularly processing, to one domain.
I have gone into the php settings and ramped that up, but wondered what else I can do?
I am running SugarCRM and importiing a lot of data, so want to speed up that process.
Any thoughts?
If you mean you want to allocate more resources to particular domain then I don’t think it is possible, however you can speed up your server by installing APC cache or xcache, gives almost 3x performance. You can also run mysql tuner to etc. to improve sql performance.
