Span elements not interpreted in bandwidth drop-down display
Webmin version 2.660
Virtualmin version 8.2.0 GPL
Webserver version Apache version 2.4.68
Related packages I don’t know
span elements representing the content of the “Show statistics for period” drop-down menu are displayed as source code.
Virtualmin > any[sub]server > Logs and Reports > Bandwidth Graph
Makes it hard to use. A patch would be welcome if next release is not planed soon.
Thanks in advance.
I can’t find that, how did you enable it?
I do think it was under Virtualmin → System settings → Bandwidth Monitoring .
But if I recall it correctly, it needs to be enabled first.
Ok, turns on and I see the same issue
In that case it should be a bug and not only a little hick-up.
Thanks for the heads-up!
We will fix it in the next Virtualmin 8.2.1 release.
You can apply the patch below right away to fix this issue:
webmin patch https://github.com/virtualmin/virtualmin-gpl/commit/46c4b91
